Moldflow Insight Forum
Welcome to Autodesk’s Moldflow Insight Forums. Share your knowledge, ask questions, and explore popular Moldflow Insight topics.
Save Quick Access Toolbar
2 REPLIES 2
430 Views, 2 Replies
Hi, I've putted some tools in the Quick Access Toolbar.
When I close Moldflow and I start it again the tools there are no more.
It seems not to be saved.
If I open the file SynergyState_enu.xlm in the
....\AppData\Roaming\Autodesk\Autodesk Moldflow Insight 2012\Release
I see:
  <QuickAccessToolBars>
    <QuickAccessToolBar ContentFile="/AirSynResourcesI18n;component/Resources/Xml/SynergyRibbon.xml">
      <Content DefaultCommands="31">
        <Items Count="14" AreCustomizeVisibilityItemPositionsFixed="True">
          <Item Cookie="Item=ID_New_New Project_" IsVisible="True" />
          <Item Cookie="Item=ID_Open_Open Project_" IsVisible="True" />
          <Item Cookie="Item=ID_ImportGeometry_Import_" IsVisible="True" />
          <Item Cookie="Item=ID_Save_Save Study_" IsVisible="True" />
          <Item Cookie="Item=ID_Undo_Undo_" IsVisible="True" />
          <Item Cookie="Item=ID_Redo_Redo_" IsVisible="True" />
          <Item Cookie="Item=ID_ActionHistory_Action History_" IsVisible="True" />
          <Item Cookie="Item=ID_Print_Print_" IsVisible="True" />
          <Item Cookie="Item=QAT_Sep1_Separator_" IsVisible="True" />
          <Item Cookie="Item=ID_QATCapture_Capture_" IsVisible="True" />
          <Item Cookie="Item=ID_CaptureOptions_Capture Options_" IsVisible="True" />
          <Separator Style="Line" Width="7" />
          <Item Cookie="Tab=ID_Reports_Reports_Reports/Panel=ID_ImagesPanel_Image Capture_Images/Item=ID_SaveImageToFile_To File_" IsVisible="True" />
          <Item Cookie="Tab=ID_Reports_Reports_Reports/Panel=ID_ImagesPanel_Image Capture_Images/Item=ID_SaveAnimationToFile_Animation_" IsVisible="True" />
        </Items>
        <StandardItems Count="11">
          <StandardItem Cookie="Item=ID_New_New Project_" />
          <StandardItem Cookie="Item=ID_Open_Open Project_" />
          <StandardItem Cookie="Item=ID_ImportGeometry_Import_" />
          <StandardItem Cookie="Item=ID_Save_Save Study_" />
          <StandardItem Cookie="Item=ID_Undo_Undo_" />
          <StandardItem Cookie="Item=ID_Redo_Redo_" />
          <StandardItem Cookie="Item=ID_ActionHistory_Action History_" />
          <StandardItem Cookie="Item=ID_Print_Print_" />
          <StandardItem Cookie="Item=QAT_Sep1_Separator_" />
          <StandardItem Cookie="Item=ID_QATCapture_Capture_" />
          <StandardItem Cookie="Item=ID_CaptureOptions_Capture Options_" />
        </StandardItems>
but in "StandardItem Cookie" I see nothing compare "Items Count".
How can I do?
thanks
2 REPLIES 2
yannick.moret
Did you try with 2013 ?
There was an issue with 2012 and windows 7 for quick access toolbar which has been solved for 2013.
in reply to: yannick.moret
Hi, thanks for the answer.
Unfortunately I have the 2012 and my company for now does not want to go to 2013.
Do you think changing the code (SynergyState_enu.xlm) you can do something?
thanks
