Moldflow Insight Forum
Welcome to Autodesk’s Moldflow Insight Forums. Share your knowledge, ask questions, and explore popular Moldflow Insight topics.
Ribbon behaviour - what do you prefer?
13 REPLIES 13
Message 1 of 14
dorinc
835 Views, 13 Replies
Hello Moldflow Users,
I have one quick question for you!  Your vote on this issue will help the Moldflow User Experience team decide how best to adjust the ribbon behaviour so that it suits your needs.
If you've tested our Scandium 2015 tech preview, you would know that we've made some changes to how the ribbon behaves.  For one thing, you can now see all the ribbon tabs at the same time, so no more having to click on the Home ribbon to get to the ribbon tab you want!  However, we would like to know what you would prefer the ribbon to do when it comes to switching between studies.
Please read the question below and then reply to this message with either Option 1, 2 or 3 in your message body.  If you reply with Option 3, please explain what you would like to see.
So, the big question is.....
When you switch from one open study to another, do you want the ribbon to:
  1. Remain unchanged – the ribbon will stay in whatever state it was in for the last study you were viewing
  2. Re-set to the state last used for the study currently being viewed – the ribbon will remember the state it was in for the study you have chosen to open and reopen in that state
  3. Other?
The User Experience team appreciate your input on this issue!
Caroline Dorin
Caroline Dorin
Snr. User Experience Manager, Generative Design & Simulation - Product Development & Manufacturing Solutions
13 REPLIES 13
Message 2 of 14
madhukeshwart
in reply to: dorinc
I prefer
" 1. Remain unchanged – the ribbon will stay in whatever state it was in for the last study you were viewing"
Some one might prefer
"2. Re-set to the state last used for the study currently being viewed – the ribbon will remember the state it was in for the study you have chosen to open and reopen in that state"
Better give both options during instance,  You can give option 1 or option 2.... yes or no type.
Madhukeshwar Talwar
FORD MOTORS PRIVATE LIMITED, Chennai
mail: madhukeshwart@gmail.com
09600060862
Please use . Accept as Solution and Give Kudos as appropriate to further enhance these forums. Thank you! .....
Message 3 of 14
dorinc
in reply to: madhukeshwart
Thanks for your feedback Madhukeshwar!
Caroline
Caroline Dorin
Message 4 of 14
inba.oneway777
in reply to: dorinc
i am ok with option 1.
But some cases like result comparisson with different studies.  i am not much comfort with the option 1.
if you give both option 1 & 2 in the view menu, based on the user preference (like a check box).
Inba Sudhahar D
Mail: inba.oneway777@gmail.com
Phone: +91-9884929216
if the answer is accepted as a solution. Give Kudos as appropriate to further enhance these forums. Thank you! .....
Message 5 of 14
in reply to: dorinc
Dear Caroline,
for me option 1 is the only one that makes sense.
In my dayly work, I usually have several studyfiles opened when comparing results only. Then, it is very annoying when the ribbons change, depending on the activated window. Thus I'd like to have the ribbons completely independent from the study fliles.
From my point of view, I cannot see any scenario where option 2 gives me an atvantage.
Best Regards
Marco
Message 6 of 14
dorinc
in reply to: inba.oneway777
Thanks Inba.  I agree that flexibility is very important in this kind of situation.
Caroline
___
Caroline Dorin
Message 7 of 14
dorinc
Great feedback, thanks Marco!
Caroline
___
Caroline Dorin
Message 8 of 14
sabarinathan1021
in reply to: dorinc
Hello Caroline,
I'll be ok with Option 01,
Option 01 would be most comfortable if we are opening multiple studies & comparing.
Option 03 would be like if you could consider that Lock & Unlock keys can be placed inside the window (water mark) like how we have view Cube inside window.
please find the below image for your reference.
Thank you
Regards
Sabarinathan. S
Core Engineering Specialist - Plastic, Auburn HIlls, USA
eMail : sabi1021@gmail.com
If U accept the solution... Give us a Kudos.... Happy Learning....Thank you! .....
Message 9 of 14
dorinc
in reply to: sabarinathan1021
Hi Sabarinathan,
Thanks for the feedback.  Can I please check that I understand your request from Option 3.
If I understand you correctly, you would like to be able to lock and unlock the ribbon state using a ribbon button , similar to the "Lock Views" button?  When this was in operation, an icon would appear in the window, similar to the Lock Views icon. Is that correct?
So, for example, if you had multiple studies open and you wanted the ribbon to remain unchanged when you switch between them, you would like there to be a button on the View ribbon called "Lock Ribbon". If that button was selected, the ribbon state would not change when you switched from viewing one study to another.
Please let me know if I have not understood you correctly.
Caroline
____
Caroline Dorin
Message 10 of 14
jim.mcguire
in reply to: dorinc
Caroline,
I vote for:
Thanks!
Message 11 of 14
mppkumar
in reply to: dorinc
I prefer
Option 1 - Remain unchanged – the ribbon will stay in whatever state it was in for the last study you were viewing
Pradeep Kumar
M P Pradeep Kumar
If my views / comments acceptable, provide "Kudos" as appreciation, if answers your query, please click the "Accept as Solution"
Message 12 of 14
sabarinathan1021
in reply to: dorinc
Hello Caroline,
Thanks for your understanding,
Yes that would be great if u implement that,
Also lock & unlock views,plots,animation buttons should be placed inside the display window like we have View Cube in a right hand top side.
It has to visible only while u placing mouse button on it for enabling & disabling purpose. so that while capturing image for our report making this will not be visible.
Regards
Sabarinathan. S
Message 13 of 14
dorinc
in reply to: jim.mcguire
Thanks Jim!
Caroline
Caroline Dorin
Message 14 of 14
dorinc
Hi Sabarinathan,
Thanks for your response.
We are still in the idea gathering stage for this developement, so we will collect as much user feedback as possible and then decide on the most suitable implementation.
Caroline
Caroline Dorin
