Moldflow Insight Forum
Welcome to Autodesk’s Moldflow Insight Forums. Share your knowledge, ask questions, and explore popular Moldflow Insight topics.
Results Through Thickness on Each Laminate
2 REPLIES 2
COzcan
395 Views, 2 Replies
Dear All; When performing a dual domain analysis we get to set number of laminae through thickness. My question is: how can we extract results on each laminate through thickness? Best Regards... Can
Can Ozcan
AKRO Engineering
can.ozcan@akroengineering.com | www.akroengineering.com
Tags (1)
2 REPLIES 2
madhukeshwart
in reply to: COzcan
probe xy plot/ xy plot...
Madhukeshwar Talwar
FORD MOTORS PRIVATE LIMITED, Chennai
mail: madhukeshwart@gmail.com
09600060862
Please use . Accept as Solution and Give Kudos as appropriate to further enhance these forums. Thank you! .....
COzcan
in reply to: madhukeshwart
Thanks for the answer. The complete solution includes specification of "profiled results" under Solver Parameters>Intermediate Output>Profiled Results set to either "Write at Constant Intervals" or "Write at Specified Times". This way one gets to plot the probe XY type plots. Also Default results set should be checked under Options>Results Best Regards... Can
Can Ozcan
AKRO Engineering
