T3, is when pressure is high
T4, is when pressure is zero
Ok maybe i have understand now.
I don't have to see the result "pressure at the end of fill", but create a new plot of pressure xy plot, then select one node in the last filled area and read from the xy graph the time of the highest value (T3) and when pressure drops to zero (T4) on the selected node in the end of fill area.
Is it right?
yes
yes
Hi Sir,
for step 2. (gate freeze) i have my XY frozen layer plot. Should i check the time when the frozen fraction stops changing/increasing for the first time ?
Because for my case, that is at 19.9 sec, and i think it's a bit too big. So my decay time (T7 = T2-T5) will then be around 15.5 sec, which is exaggerated.
thanks.
