Moldflow Insight Forum
Welcome to Autodesk’s Moldflow Insight Forums. Share your knowledge, ask questions, and explore popular Moldflow Insight topics.
Reactive Molding
1 REPLY 1
yaman41
435 Views, 1 Reply
Reactive Molding
I want to perform a reactive molding simulation in insight. I will use a custom EPDM material.I only have viscosity,curing graphs and density data about this EPDM.Is ıt possible to define a custom material with these? What should i do about this case?
Best Regards.
Tags (2)
1 REPLY 1
nordhb
in reply to: yaman41
if you have measured data, raw data, of material you can contact datafittingmoldflow@autodesk.com
and supply the raw data and get measured data fitted and an udb-file for analysis in return.
You can also test material as service.
Please, see:
http://www.autodesk.com/moldflow-labs
for more information.
Hope this helps.
Berndt
Berndt Nordh
