The second technology preview of Project Radium for Mioldflow Insight users is now available on Labs. The second Moldflow Radium Technology Preview has improvements in all areas of Technology Preview 1.
The Autodesk Moldflow Radium Technology Preview showcases some of the next generation capabilities for Autodesk Moldflow Insight:
You can download the Autodesk Moldflow Radium technology preview from the Radium Labs page (click here for the Japanese page).
Also follow the other Autodesk Technology previews on labs here.
For questions and feedback, please send an email to: labs.moldflow.radium@autodesk.com
What happened to the transient_cool analysis (Cool_FEM). ??
is it removed from Radium Technology Preview II?? Will it be provided in new Version ? or for (Cool_FEM) do we need to buy some additional feature???
Thanks a lot for the information in advance
TC
Cool transient FEM is part of Radium TP2, as it was from Radium TP1.
Check in the analysis sequence menu, click on more, and you should see the cool (fem) sequence available.
Not this feature is only valid for 3D models.
Regards
ach ok
Thanks a lot i think i have to check the installation once again becuase i cant see the Cool FEM analysis
TC
Is there a way to switch between the old and new user interfaces or do I have to uninstall and reinstall to do that?
Hi Pete.
Yes you can switch within the UI.
If you are in the Classic GUI: go to File > Options (previously called User preferences) > select Classic from the 'Interface style" on the bottom of the 'General' tab.
If you are in the Ribbon GUI: go to the Large 'M' button > Options (bottom right corner) > select Classic from the 'Interface style" on the bottom of the 'General' tab.
The user interface will change when it's opened next time.
Hanno
been using it for a month or so .. evaluating the venting with some decorative parts.
seems to be woring pretty well .. a few glitches here and there though to fix
Hi Mike,
Can you please provide some feedback as to which glitches need to be fixed? This would be helpful to get them resolved.
Hanno
Will keep tabs on things .. using it every day ( so it is stable )
GUI stuff for the most part , it seems
