As you can see in attached file i am not able to see "Allow Docking" option in my Autodesk moldflow insight 2011.
All panels are freely floating.
can anyone please help me in this regards?
help would be highly appreciable.
Mayur D.
what you can do is:
If a pane will not dock, right-click anywhere in the border of the pane and ensure that Allow Docking is selected.
(recommend use the border at left, bottom, or right of the pane for the right-click, as top is for the move)
The one can dock again.
or
Start > Programs > Autodesk > Autodesk Moldflow Insight 2011 > Autodesk Moldflow Insight 2011 Command Shell
cleanreg <enter>
This will reset personal settings and parameters, and the menus will be docked when starting Synergy.
Berndt
