Hi team,
I can't dock a study task panel in ASMI.
I clicked a empty space and right click, It doesn't show a "Allow docking" and "hide" menu.
I search a similar case. "Allow Docking" option isn't available, All panels are floating.
So I run a cleanreg.exe. then, noting changed.
Can anyone help me this issue?
Kind Regard,
Sujin.
Hi Sujin,
That original issue was mine luckily, so i can ask you to do this:
As Andrea stated correctly you will need to Right click of your mouse button infront of Tasks & Tools tab (just below the Project bar), you will get 'Allow Docking' option, after that just drag the project window to desired location, it will dock automatically.
This will solve your problem.
Best Regards,
Mayur
Hi, Andrea, Mayur,
Thank you for your kind response.
the strange thing is when I clicked a next to the task and tools tap, Nothing happened.
However the layer panel and notes panel are normally worked.
So I tried to run cleanreg.exe.
However the "Allow docking" menu still does not show.
Kind Regard,
Sujin.
Hi, Andrea and Mayur,
Yes. I tried to run as Administrator that file.
How can I share my screen?
My email address is sj.hwang@ednc.com
Kind Regard,
Sujin.
Hi Aravind,
Thank you for your help.
I couldn't cleanreg file both Synergy and insight 2014.
and also another customer has same issue.
Can you check this file and send me?
Kind Regard,
Sujin.
Hi Mayur,
There is not cleanreg.exe file.
I using win 7 64 bit Korean version and ASMI 2014 SP2 in English version.
I just called a david lee in ADSK Korea ASE.
He said also he has not cleanreg.exe in 2014 version.
Can you check attached pictures?
and If you possible, Can you send me that file for my email?
Thank you very much.
Kind Regard,
Sujin.
Hi everyone,
Thank you for all your help.
It solved.
I contact my customers and all of them fixed. 🙂
Thank you very much!
Kind Regard,
Sujin.
