I am running a Process optimization analysis in AMI 2012 and I got the following error
Please Help.
Thanks in advance,
Vikas
{Determining Stroke Requirements...
Determining Optimal Velocity Phase...
Iteration Temp Drop Temp Dev. Max Shear Rate Max Shear Stress
(C) (C) (1/s) (MPa)
** ERROR 1300290 ** Unable to open OTM file.
0 0.0000 0.0000 0.0000 0.0000
Determining Optimal Pressure Phase...
** ERROR 1300330 ** Unable to open OF1 file.
** ERROR 1300500 ** An error occurred launching a flow analysis. The process
optimization analysis cannot continue.
** ERROR 1300100 ** Optim solution failed.}
the resolution of
is to check the disk space and write permissions for the Job Manager temporary directory of the machine where you ran the analysis. If necessary, delete the files in the temporary directory to recover space, or set a different Job Manager temporary directory, then rerun the analysis.
Berndt
