Discussion Groups
Simulation Moldflow Insight
mtrujil1
Problems to install the Moldflow Insight 2012 Version
320 Views, 2 Replies
02-13-2014 03:48 PM
Hello Everyone!!
i have a problems to re-install the moldflow 2012 version, know i have installed the 2014 Premium version and our team found a lot of differences on the results (specifically on Pressures Results & Clamp Force, around 30%).
we downloaded 2012 Insight Premiun version, and we install the next topics with these Poduct keys:
Autodesk Molflow Insight Performance 2012 (P K:574D1)
Autodesk Moldflow Sinergy 2012 (P K:579D1)
Autodesk Desing Link 2012.
But after the installation, when i want run a new analysis (Fill + Pack) appears a error 99998 message :
"Required license for AMI_BASIC is not available, or all licenses are
currently in use or the product you have installed is not licensed to
run this feature".
Please help me, because i undestood that error is for a Basic version, and never downloaded that version. i read on this community similar problems and they recommend change the product key, but i dont know wich key will be correct.
im attaching a ppt file to describe the Problem.
Regards
Please use plain text.
Valued Contributor
tim.vanast
Re: Problems to install the Moldflow Insight 2012 Version
02-14-2014 11:25 AM in reply to: mtrujil1
I think that 2012 uses a different license server than 2014.  So double check that the old license server is installed and loaded with the old licenses.
Tim.
mtrujil1
02-14-2014 11:52 AM in reply to: tim.vanast
But normally, the current versions support the las versions o no????
my fellow worker has both versions!
