Hello Everyone!!
i have a problems to re-install the moldflow 2012 version, know i have installed the 2014 Premium version and our team found a lot of differences on the results (specifically on Pressures Results & Clamp Force, around 30%).
we downloaded 2012 Insight Premiun version, and we install the next topics with these Poduct keys:
Autodesk Molflow Insight Performance 2012 (P K:574D1)
Autodesk Moldflow Sinergy 2012 (P K:579D1)
Autodesk Desing Link 2012.
But after the installation, when i want run a new analysis (Fill + Pack) appears a error 99998 message :
"Required license for AMI_BASIC is not available, or all licenses are
currently in use or the product you have installed is not licensed to
run this feature".
Please help me, because i undestood that error is for a Basic version, and never downloaded that version. i read on this community similar problems and they recommend change the product key, but i dont know wich key will be correct.
im attaching a ppt file to describe the Problem.
Regards
I think that 2012 uses a different license server than 2014. So double check that the old license server is installed and loaded with the old licenses.
Tim.
But normally, the current versions support the las versions o no????
my fellow worker has both versions!
