Moldflow Insight Forum
Welcome to Autodesk’s Moldflow Insight Forums. Share your knowledge, ask questions, and explore popular Moldflow Insight topics.
Problem! Mesh & wire sweep results.
0 REPLIES 0
Message 1 of 1
387 Views, 0 Replies
Hallo,
as far as I know, once the mesh element size above a critical point,  the wire sweep or other results should have negligible difference. But in my simulations, the element size is already huge but the wire sweep results seem still not ideal.
From my results, I don't know which mesh GEL I should use for the further simulations.
Which mesh GEL has the higher accuracy in my case?? The wire sweep should be as small as possible but I don't think the smallest mesh GEL is a good choice.   It confused me and i cannot go further!
Here some results are enclosed. Thank you all very much!
Greetings from Munich,
Liu
0 REPLIES 0
