Moldflow Insight Forum
Welcome to Autodesk’s Moldflow Insight Forums. Share your knowledge, ask questions, and explore popular Moldflow Insight topics.
Prediction of fiber orientation with auto-calculated Ci
1 REPLY 1
402 Views, 1 Reply
Hi to all,
according to the Moldflow helpfiles, using the Folgar-Tucker model with auto-calculated Ci during a fiber orientation analysis, the Ci-parameter is calculated with help of an empirical database. Therefore, I would like to ask, if it is possible to access this database and if not, which data is used to calculate the Ci-parameter?
Thank you for any answers!
1 REPLY 1
Alex.Bakharev
When you select this option the Ci is calculated from the average thickness of the cavity by an empirical formula.
