After click " start analysis" I saw this report:
Copyright Autodesk, Inc. All rights reserved.
(C)2009 2010 2011 2012 2013
Portions of this software are covered by U.S. Patent Numbers 5,287,408 and 6,096,088.
Flow Analysis
Version: ami2014-cerium_compile_windows-x64 (Build 13095-314)
64-bit build
Analysis commenced at Mon Feb 17 09:20:08 2014
Analysis running on host: LICH-PC
Operating System: Windows 7 Service Pack 1
Processor type: GenuineIntel Intel64 Family 6 Model 58 Stepping 9 ~3000 MHz
Number of Processors: 4
Total Physical Memory: 8134 MBytes
No mesh for the cores was found.
Core shift analysis switched OFF
** ERROR 99998 ** Required license for AMI_STANDARD is not available, or all licenses are
currently in use or the product you have installed is not licensed to
run this feature.
plz help me how can i solve?
you License is from a Compay or now u are using the student version???
if your license is from corporate, maybe you need contact to autodesk support, because yesterdaty i sent a note to request support for the same problem, and they answered that only the reponsable for IT has a authorization to discharge othter versions!!!
We have a saying "You get what you pay for"
In this case, you paid for nothing so you get nothing! I personally wouldn't go around on the forums of the developer and ask how I can steal their product.
I have this issue when I run jobs on another computer (clustering). The way I fix it is to restart said computer and it works just fine for a day or so. I use 2014. If that doesn't work for you, I would try to re-install the software.
