this is not so easy with not having the study to troubleshoot.
Make sure you do not have overlaid curves/lines that creates overlaid mesh and nodes.
Turn of elements, and keep curves/lines.
(You might need to assign beam elements to a separate layer first, to make sure all curves/lines can be found)
Turn on: View>Toolbars>Selection
Do a banded selection of line in area of problem. If overlaid, in the selection list you will see more than one curve entity.
(Or, click on line in area of problem. If overlaid, the highlight of line normally do not shine through.)
Use Mesh Diacgnostics and
- Cooling Circuit Diagnostics
- Bubbler/Baffle Diagnostics
to check cooling circuits.
If overlaid nodes, you can try Global Merge with a small tolerance, such as 0.001mm.
Be careful, as it can distort your model if too large tolerance depending on model size/ mesh size.
Choose it wisely, as this affects all nodes in model.
Also, this can create issues on baffles/bubblers, if they lines are on top of each other and not
a small V-shape. (See Help and Modeling baffles.)
Berndt
Berndt Nordh
