Can anyone suggest how to find out air gap if plastic shrinks internally or lose the contact between plastic & insert.
refer attached image for better understanding.
or ... Is moldflow assumes perfect contact between plastic & insert interface??
BV
Hello BV,
To comment on the Moldflow side regarding the contact. Moldflow uses default heat transfer values to represent different levels of contact throughout an analysis.
Fill-->5000 W/m^2-C
Pack-->2500 W/m^2-C
Detached Cavity/Core-->1250 W/m^2-C
Where the flow solver automatically detects the instant the detachment occurs based on pressure in 90% of the cavity having decayed to zero. So there is definitely not perfect contact assumed.
Hi Justin,
Many thanks.
I understand your reply of different heat transfer values during the process.
May be I have not put my question correctly.
I'm analyzing insert molding with core shift analysis on.
I can see insert deformation during the process & wall thickness variation as well.
But, practically after molding there is no contact of plastic with metal insert & insert is free to move inside.This is critical for part performance.
May be this must have happned due to internal shrinkage or difference in co-efficient of expansion or some other factor.
I can't see such condition/plot in my simulation to co-relate. Please help me to atlest zeroing the possible cause.
BV
