In order to run an analysis with a thermoset material you need the Reactive Molding license, or else you can't choose a thermoset material to run the analysis.
I'm also looking for phenolic materials in the database to run an analysis, more specifically Bakelite PF 31, but there isn't any alike. Has someone tested this material or one with similar properties and created a MF file in the database? Sharing would be highly appreciated.
Carlos
in Synergy and tab Home, select the molding process to Reactive Molding (or other thermoset process) to get access to reactive material database.
The thermoset simulation is a part of Autodesk Moldflow Insight Basic, Performance and Advanced.
See product packages features at: http://usa.autodesk.com/adsk/servlet/pc/compare/index?siteID=123112&id=14920771
So, if you have Autodesk Moldflow Insight Basic, you can run thermoset Reactive Molding simulation.
There are some PH, phenolics, in the database.
Berndt
