Moldflow Insight Forum
Welcome to Autodesk’s Moldflow Insight Forums. Share your knowledge, ask questions, and explore popular Moldflow Insight topics.
Part Insert - Magnet
2 REPLIES 2
klp2kor
875 Views, 2 Replies
In one of the insert molding simulation I have to use Neodymium Iron Boron (NdFeB) magnets as part inserts but I am not able to find this material in AMI 2013 liberary. Perticularly I have to capturure the temperature variations in the magnet during modling.
Please suggest.
KLP
2 REPLIES 2
nordhb
in reply to: klp2kor
if you can get the material properties from material supplier you can use it in analysis.
(generally : http://en.wikipedia.org/wiki/Neodymium_magnet#Properties )
You can edit the part insert material properties directly:
Select the part insert elements:
Right-click > Properties...
Field: Metal > To the right "Select..."
"Edit..."
This will be for the specific analysis setup.
You can also create a personal database, to create a material for selection:
tab Tools > New
Property Type : Mold material
To the left of OK button click "..." to giva a name to the database
You now can create a new material.
Or, you can copy from database and change via:
In righ lower corner click "Databases >>"
Select material.
Click "Copy".
Then Edit the material as wished.
Exit with OK.
When you select the mold material, you need to change "All mold material (System)" to "All mold material (User)" to find the your personal database or use the "folder open" button to select a mold material udb-file.
Hope this helps.
Berndt
Berndt Nordh
akhebir
Inventor has a magnetic add-in, EMS.  It has a library of permanent magnets.  Link: http://www.emworks.com/product/preview/1/EMS
