Good day all,
I have this project where I need to overmold two assembled inserts made from plastic. From scheme attached to this post 1, 2 are assembled inserts and 3 is part which will be injected. So I want to run FEM analysis with MF to see if and how inserts 1 and 2 will be deformed because of pressure. And my question would be if it is possible to define contact between inserts 1, 2 and how to do that.
Thanks in advance,
ArunasP
In Moldflow you can mesh 3 parts at a time using precise match option, so negotiating with intersections, overlapps, etc. no need to define contact.
You cant define contact between parts here.
