Discussion Groups
Simulation Moldflow Insight
Valued Contributor
prabu27
Overmolding analysis (warpage)
222 Views, 2 Replies
10-23-2013 04:26 AM
hello,
             i want to run Warp analysis in overmolding process, there is no option available for warp analysis.
i have done mesh using dual domain meshing. Using moldflow insight 2011 version..
How to run this analysis?
Please use plain text.
Gui_81
Re: Overmolding analysis (warpage)
10-24-2013 04:33 AM in reply to: prabu27
Only with 3D mesh is possible to run warpage with overmolding.
Bet regards
Valued Contributor
prabu27
10-24-2013 04:35 AM in reply to: Gui_81
hi,
thank you .....
________________________________
DISCLAIMER:
This email may contain confidential information and is intended only for the use of the specific individual(s) to which it is addressed. If you are not the intended recipient of this email, you are hereby notified that any unauthorized use, dissemination or copying of this email or the information contained in it or attached to it is strictly prohibited. If you received this message in error, please immediately notify the sender at Infotech and delete the original message.
