Moldflow Insight Forum
Welcome to Autodesk’s Moldflow Insight Forums. Share your knowledge, ask questions, and explore popular Moldflow Insight topics.
Overmolding analysis (warpage)
2 REPLIES 2
prabu27
587 Views, 2 Replies
hello,
             i want to run Warp analysis in overmolding process, there is no option available for warp analysis.
i have done mesh using dual domain meshing. Using moldflow insight 2011 version..
How to run this analysis?
2 REPLIES 2
in reply to: prabu27
Only with 3D mesh is possible to run warpage with overmolding.
Bet regards
prabu27
hi,
thank you .....
________________________________
DISCLAIMER:
This email may contain confidential information and is intended only for the use of the specific individual(s) to which it is addressed. If you are not the intended recipient of this email, you are hereby notified that any unauthorized use, dissemination or copying of this email or the information contained in it or attached to it is strictly prohibited. If you received this message in error, please immediately notify the sender at Infotech and delete the original message.
