We are trying to run only fill analyses (3D) for multi cavity mold with parts inserts with applying occurrence number.
We could able to apply occurrence number to parts elements, feed system beam elements, but we could not assign occurrence number parts inserts (tetra elements).
As per mold flow help, it should be possible to assign a occurrence to parts inserts also, but we failed to assign occurrence number.
But when we try to applying occurrence number to parts inserts (3D) at properties, there is no option for occurrence number.
Is it possible to apply occurrence to part insert or not?
If yes how to apply? If not any other alternative to do so?
Madhukeshwar Talwar
Solved by nordhb. Go to Solution.
Hi madhu
I know in Core shift analysis you can not apply occurance number for the 3D core
Part insert in 3D analysis it is not possible to apply occurance number to part insert
TC
Sadashiv
you do not need Occurrence number for part insert.
Occurence numbers are used by the flow solver basically as a factor for the volume of material to fill.
It is there to simplify the model, and to take into account the different identical flow paths and cavities in volume calculation.
