does anyone knows why when i try to modify the number of frames of a fill time animation to 300 so that i can see more detail on the mfr file, it does not update the run???
i tried to first export a fill time file with 99 frames, and then i modified the result on teh insight study, but the communicator is still recognizing only the 99frames, and not the one with the 300 fframes....
does anyone knows also, if you can modify the frames on the communicator software? apparently not, right?
thanks,
