Moldflow Insight Forum
Welcome to Autodesk’s Moldflow Insight Forums. Share your knowledge, ask questions, and explore popular Moldflow Insight topics.
New material database
3 REPLIES 3
donAmaruSarma
720 Views, 3 Replies
Hi Guys,
My name is Guru, I am doing my masters project with Autodesk Moldflow. I actually have a thermoset material which can't be found in the material list. How can I add this material?
Will appreciate a quick response. thanks Edited by: donAmaruSarma on May 27, 2010 10:53 AM
3 REPLIES 3
nordhb
in reply to: donAmaruSarma
if you have this material data already fitted for analysis in a .udb-file
you can use Select Material and Import...
Or put udb-file in folder such as C:\My AMI 2011 Projects\udb
The filename will be in field Manufacturer when Select Material
If this is raw data, to be fitted for analysis, please contact:
datafittingmoldflow@autodesk.com
Autodesk Moldflow Plastics Labs
information at:
http://usa.autodesk.com/adsk/servlet/item?id=13151393&siteID=123112&linkID=13030537
Berndt
Berndt Nordh
pk_vel
Hai Guru,
Do you have the datasheet for ur material?
If not try to find it in http://prospector.ides.com. or http://www.ides.com.
After knowing its properties you can even try to go for alternate grade with same family and properties that are available in Moldflow database.
Regards
P K VEL
Well Guys thanks for replying. I have the material data sheet, MSDS everything on hand. I'll e-mail the autodesk people to get them transfered into udb file.
Best Regards,
Guru
