if you have this material data already fitted for analysis in a .udb-file
you can use Select Material and Import...
Or put udb-file in folder such as C:\My AMI 2011 Projects\udb
The filename will be in field Manufacturer when Select Material
If this is raw data, to be fitted for analysis, please contact:
datafittingmoldflow@autodesk.com
Autodesk Moldflow Plastics Labs
information at:
http://usa.autodesk.com/adsk/servlet/item?id=13151393&siteID=123112&linkID=13030537
Berndt
Berndt Nordh
