Sometimes, in the results of the flow rate, the values are negative. Why?
Solved by nordhb. Go to Solution.
basically negative flow rate means a backflow.
The reason for this, is a that cavity is pressurized and when pressure is released at V/P switchover,
the flow follows path of least resistance, and sometimes becomes a backflow through gate, hence negative.
You should be abble to see this on velocity plot, and vectors as darts, how they change direction.
If modeled runner beams, you should be able to see the negative flow rate in beams.
Hope this clarifies.
Berndt
Dear Nilza,
everybody had this before - I wouldn't mind
Moldflow could even flow "filled Volume" backwards:
| 2.996 | 98.360 | 1.146e+02 | 1.09e+02 | 5.076 | 2.94 | P |
| 3.004 | 98.369 | 1.146e+02 | 1.10e+02 | 4.815 | 2.97 | P |
| 3.014 | 98.380 | 1.146e+02 | 1.12e+02 | 4.033 | 3.00 | P |
| 3.030 | 98.397 | 1.146e+02 | 1.14e+02 | 3.194 | 3.07 | P |
| 3.073 | 98.445 | 1.146e+02 | 1.15e+02 | 2.203 | 3.23 | P |
| 3.222 | 98.577 | 1.146e+02 | 1.12e+02 | 1.124 | 3.84 | P |
| 3.821 | 98.579 | 1.146e+02 | 9.00e+01 | 0.495 | 6.99 | P |
| 4.821 | 98.567 | 1.146e+02 | 5.44e+01 | 0.168 | 13.63 | P |
| 5.821 | 98.556 | 1.146e+02 | 2.90e+01 | 0.069 | 23.45 | P |
| 6.821 | 98.549 | 1.146e+02 | 1.63e+01 | 0.053 | 38.08 | P |
| 7.821 | 98.542 | 1.146e+02 | 1.12e+01 | 0.048 | 59.25 | P |
Funny isn't it.
