Hello All,
We have a part which is manufactured by Mucell + Injection compression process.
It has got two parts (Part A & Part B). Part B is with Mucell & Part A is molded over part B by injection compression process.
First the Part B is injected then the mold table rotates & inject part A with injection compression process.
My question is : Can i simulate this combined Mucell + Injection compression in Moldflow ?
Your views are appreciated.
Thanks in advance.
Anoop v Ravi
Hi Anoop,
At the moment, you cannot simulate this sequence. You can simulate the Mucell process, and the Compression molding with a plastic insert seprately, but not integrated in one analysis sequence.
We are starting to see more combinations of processes in the last few years and are following this closely.
Hanno
Anoop,
May be you need to submit request in Idea station ....
