Dear user,
Please give me information about Tg and Viscosity v/s shear rate curve for PP Moplen EP 5015.
Moplen EP 5015 is currently not in the material database.
What you can do:
- Look up data at material supplier site
- Contact the material supplier and ask for an udb-file for the material, and/or other material properties. The udb-can be used to view material properties.
- Contact the material supplier and ask for an equivalent udb-file for the material, or to use an equivalent material data from the material database.
- If you have measured data, raw data, of material you can contact datafittingmoldflow@autodesk.com and get measured data fitted and an udb-file for analysis in return. (material supplier might have measured data of this material?)
Autodesk Moldflow Plastics Labs information at:
http://usa.autodesk.com/adsk/servlet/item?id=13151393&siteID=123112&linkID=13030537
Hope this helps.
Berndt
