Moldflow Insight Forum
Welcome to Autodesk’s Moldflow Insight Forums. Share your knowledge, ask questions, and explore popular Moldflow Insight topics.
Moldflow Suitable for EPS Packaging Design?
6 REPLIES 6
emailoshea
683 Views, 6 Replies
Our company is due to startup a new production facility manufacturing packaging from moulded EPS.
Would Moldflow be a suitable tool for our design engineers who are familiar with Autodesk. Does anyone have experience of using Moldflow for EPS packaging?
6 REPLIES 6
mayur_dhumal
in reply to: emailoshea
May i know which BMM you are using? With some workaround i think you may be able to use moldflow simulation software. You can contact local customer support (Technical) for Autodesk.
Mayur
emailoshea
in reply to: mayur_dhumal
Thank you for the reply. Sorry but what does BMM mean?
mayur_dhumal
I mean which type of machine do you use? machine specifications?
Mayur
emailoshea
Kurtz A-Line Shape Moulding Machines
http://www.kurtz-services.com/a-line-en.html
madhukeshwart
  • EPS molding simulation is not possible in moldflow.
  • 'Microcellular injection molding analysis' may help you.
  • Call to local Autodesk support team.
Refer this link, which may be helpful to you
http://www.flow3d.com/pdfs/tp/cast_tp/simulation-of-EPS-foam-decomposition-in-the-lost-foam-casting-...
Madhukeshwar Talwar
FORD MOTORS PRIVATE LIMITED, Chennai
mail: madhukeshwart@gmail.com
09600060862
Please use . Accept as Solution and Give Kudos as appropriate to further enhance these forums. Thank you! .....
emailoshea
in reply to: madhukeshwart
Thank you.
