I installed the Moldflow Insight 2014. Due to some error, i uninstalled it but when i tried to install it again it is showing that its already installed.
need to reinstall it.
Please provide me the solution.
Regards
Assuming you installed Insight under "C:\Program Files\Autodesk\Simulation Moldflow Insight 2014" folder, otherwise you need to use your installed location to replace this one. I also assumed that you installed 64 bit of Insight. You can try to uninstall from Windows command window:
msiexec /x {753C779D-0464-2014-0000-8FF1C120CB5E} INSTALLDIR="C:\Program Files\Autodesk\Simulation Moldflow Insight 2014"
Charlie
Dear Charly,
If that ..."msiexec /x {753C779D-0464-2014-0000-8FF1C120CB5E} INSTALLDIR...." works, your are my personal hero.
I destroyed 3 Win 7 installations with this issue myself and I tried to manually delete Autodesk out of my registry - I know software that have 3 to 10 entries, not Autodesk, think I deleted about 5.000 entries.
But problem was still....If Charlies advice didn´t work you have to re-install. (and send invoice for that to Autodesk ;-))
Jay
Have you managed to uninstall 2014 Insight yet? Please let me know if you still have trouble to uninstall it.
Charlie
