Discussion Groups
Simulation Moldflow Insight
New Member
ashutoshkumar.del
Moldflow showing installed even after uninstallation
163 Views, 3 Replies
04-11-2014 05:18 AM
I installed the Moldflow Insight 2014. Due to some error, i uninstalled it but when i tried to install it again it is showing that its already installed.
need to reinstall it.
Please provide me the solution.
Regards
Please use plain text.
zhangchar
Re: Moldflow showing installed even after uninstallation
04-13-2014 05:11 PM in reply to: ashutoshkumar.del
Assuming you installed Insight under "C:\Program Files\Autodesk\Simulation Moldflow Insight 2014" folder, otherwise you need to use your installed location to replace this one.  I also assumed that you installed 64 bit of Insight.  You can try to uninstall from Windows command window:
msiexec   /x {753C779D-0464-2014-0000-8FF1C120CB5E} INSTALLDIR="C:\Program Files\Autodesk\Simulation Moldflow Insight 2014"
Charlie
Active Contributor
JayMuller
04-22-2014 12:49 AM in reply to: zhangchar
Dear Charly,
If that ..."msiexec   /x {753C779D-0464-2014-0000-8FF1C120CB5E} INSTALLDIR...." works, your are my personal hero.
I destroyed 3 Win 7 installations with this issue myself and I tried to manually delete Autodesk out of my registry - I know software that have 3 to 10 entries, not Autodesk, think I deleted about 5.000 entries.
But problem was still....If Charlies advice didn´t work you have to re-install. (and send invoice for that to Autodesk ;-))
Jay
zhangchar
04-22-2014 04:03 PM in reply to: JayMuller
Have you managed to uninstall 2014 Insight yet?  Please let me know if you still have trouble to uninstall it.
Charlie
