Discussion Groups
Simulation Moldflow Insight
MehtaMJ
Moldflow Communicator
279 Views, 1 Replies
02-19-2013 11:45 AM
I will appreciate if someone can tell me producer to compare (2) 'mfr' report file in communicator. Procured in help is not working
Please use plain text.
petr_AL
Re: Moldflow Communicator
02-22-2013 05:03 AM in reply to: MehtaMJ
as I know, only two studies in one .mfr file are possible to compare in Moldflow Comunnicator, not two different .mfr files.
If you select two studies at Moldflow Insight to export (using Ctrl) to .mfr, you will have both in the one .mfr file.
More then 2 studies is not possible to export together.
Petr
