I'm new at using moldflow and I have some questions about the software. I have a mold design for a part that I want to produce, but the cavity and core of the mold are not made by conventional ways.
Is there away to tell moldflow that the specific part is the cavity and the other the core of the mold, instead of creating the mold surface on the software?
I would be happy if anyone can help me.
Select your elements, and look at properties. You have the possibility to define the mold material.
So you can select elements on both side of your model, and assigned different properties.
Surely,
If not clear, Take a help of local Autodesk support...
