Moldflow Insight Forum
Welcome to Autodesk’s Moldflow Insight Forums. Share your knowledge, ask questions, and explore popular Moldflow Insight topics.
MF insight?
2 REPLIES 2
RobTharp8567
385 Views, 2 Replies
MF insight?
Rev 2013 - Is there a way to copy study 'Process Settings' from one study to another?
2 REPLIES 2
in reply to: RobTharp8567
Hi, Rob
The easiest way I can think of is the following:
  • Duplicate the study with the properties you want to use (right click on the study and press "Duplicate".
  • Rename the duplicated study. Select al the model entries (e.g. Go to Geometry ribbon and press the third icon in the secon raow of the "Selection" section) and delete them. Now your model is empty but all the properties intact
  • Select "Add an existent model to the study" (The Insight button/Open/Add - menu combination). Select the study with the corrct geometrical model. Now you have the study with the parameters completely copied from the first study but with the model from the second study that  was I believe you wanted.
P.S  Please take into account that if you need to reselect a material then the Temperatures of Melt and Mold might change to the recommended for the new material. You might want to the change them back - it is just two numbers. No other process parameters change if you reselect the material.
RobTharp8567
Thanks! Makes perfect sends e and worked great. I run a lot of flow leaders options, geometry changes and want an apples to apples process to review. Sure seems like an easy software update? [Description: Description: Description: Description: Description: Description: Description: Description: Description: Description: Description: Description: C:\Documents and Settings\NPG10248\Desktop\Bemis Logo.jpg]Robert D. Tharp | Predictive Engineering and Design Advanced Technology Group | Bemis Manufacturing Company 300 Mill Street | Sheboygan Falls, WI 53085 W 920-467-8775 | robert.tharp@bemismfg.com This message, including any attachments, contains confidential information intended solely for the addressee. If you are not the intended recipient, you should not view, disseminate, distribute, print, or copy this message; please notify the sender immediately and permanently delete this message, including any copies thereof.
