Hello to everybody. I would like to know if it is possible to simulate metal injection molding using Moldflow, and in particular if it is possible to evaluate density gradient of mel powder inside the part.
Thanks in advance
Marco Salvador
Hello Marco,
We've had a few users that have attempted to simulate MIM, but there are a few obstacles to overcome.
In the end, the software was not designed for this purpose so we do not officially support it. The users that typically try to simulate MIM seem to be mainly concerned with fill patterns so I'm not familiar with anyone that has tried to evaluate the density gradient within a part.
Hi Shawn,
Can you please let me know if we've the MIM module (Metal injection Molding) in Moldflow 2015 ?
Regards
Ram
Hey,
I use Moldflow 2015. I guess you refer to the type of process that can be selected in Moldflow, when you ask for the metal injection module. There is no dedicated module available for metal injection molding, as you can see in my attached screen shot.
However, the molding steps of metal injection molding and thermoplastic injection molding are procedure-wise alike. Hence, you can basically use the thermoplastic injection module in Moldflow for metal injection molding.
Still, there are some differences regarding the behavior of the used materials, as Shawn points out nicely. Metal feedstocks have much higher density, inertia can become important again, wall slip is likely to occur, some people even have experienced shear thickening. Besides that, there is usually not enough mechanical and rheological data of the feedstocks available for using it in Moldflow.
If the data base is sufficient, it should be possible to simulate metal injection molding meaning the software can handle it and you will get some result. As Shawn mentioned, it can give you an idea about the flow behavior. The numbers are not reliable or accurate though. I do not know either whether the density gradient evaluation is technically possible or whether it makes sense due to the aforementioned issues and inaccuracy.
Best regards,
Max
Hi Max,
Thank you very much for the quick reply .Also I appreciate the details shared .
Ram
Hey Everyone,
I think there are number of and quick ways for metal injection moulding ..
Metal injection moulding have some fundamental requirements in each step of the process.. like Metal powder, binders,mixing, moulding, De-binding, Sintering, Post sintering operations,
With the years of experience in precision we manufacture silicon injection molding products that help saving our customer’s time & money. Click here to know more!
silikontechnologies.com
