Moldflow Insight Forum
Welcome to Autodesk’s Moldflow Insight Forums. Share your knowledge, ask questions, and explore popular Moldflow Insight topics.
Mesurement Scale in 2015 issue
2 REPLIES 2
rmathan
283 Views, 2 Replies
In 2015 Version
Measurement scale not working properly while checking dimensions.
Even though filtering nearest node check box, the scale picks somewhere and shows wrong dimension. I am facing this problem often. Software developers kindly help to fix this issue.
Mathan
2 REPLIES 2
madhukeshwart
in reply to: rmathan
Mathan,
We are not facing any such issue. May be the way you are using might be wrong.
1. Zoom in and try select node
2.  set snap to pull down to nearest node.
check and confim
Madhukeshwar Talwar
FORD MOTORS PRIVATE LIMITED, Chennai
mail: madhukeshwart@gmail.com
09600060862
Please use . Accept as Solution and Give Kudos as appropriate to further enhance these forums. Thank you! .....
rmathan
in reply to: madhukeshwart
Hi Madhu,
I have tried with Zoom in and I always keep sanp set to nearest node. It happens average 10 times out of 30 times.
It should not happen if we set snap to nearest node. I have never faced in earlier versions even though i check dimension with zoom out.
Mathan
