Moldflow Insight Forum
Welcome to Autodesk’s Moldflow Insight Forums. Share your knowledge, ask questions, and explore popular Moldflow Insight topics.
Meshtransfer from Moldflow to Hypermesh
1 REPLY 1
phammer
707 Views, 1 Reply
Hi everybody,
ist it possible to export a mesh of the moldflow mesher, so that I can import it to hypermesh?
Patran is not working in my case!
Greetings
Philipp
1 REPLY 1
nordhb
in reply to: phammer
you can publish to Altair .h3d :
S > Publish > Altair Hyper3D.
Please, see:
ASMI Help >  User's Guide > Import and Export > Exporting models and files > Publish to Altair Hyper3D
or
http://help.autodesk.comview/MFIA/2014/ENU/?url=//cloudhelp/2014/ENU/MoldflowInsight/files/GUID-7775...
You need at least HyperView 9.0.
I have no experience of if the mesh in the .h3d-file can be used further.
Maybe someone in the forum has.
You might also be able to use an script from command line, mpi2-command, such as mpi2nas and more.
Look up help for further export commands.
Hope this helps.
Berndt
Berndt Nordh
