Moldflow Insight Forum
Welcome to Autodesk’s Moldflow Insight Forums. Share your knowledge, ask questions, and explore popular Moldflow Insight topics.
Meshing_Global Edge Length influence on simulation results
1 REPLY 1
J_Liu
486 Views, 1 Reply
Hello together,
i'm running a simulation for wire sweep and tried several global edge length from 0.3 to 5 in meshing step. In those 8 different simulations, the wire sweep deflecion results are quite different and viscosity, velocity, shear rate results are all different from each other!  Thus i am confused, how does GEL value influent the simulation results??  and which GEL should i set to get the accurate result for the wire sweep simulation??
Look forward to your kind reply! Thank you!
1 REPLY 1
J_Liu
in reply to: J_Liu
for example.  When global edge length decreases, the wire sweep deflection also decreases. But when GEL reaches 0,3(the lowest value i used), the wire sweep deflection is higher!  Is anyone know the rule between GEL and results?
