Hello everyone
I have the following problem in Moldflow 2012:
1) I mesh a model with a 3D mesh (mesh sizes between 200k to 600k elements).
2) I run the mesh repair wizard, which it is very slow. It sometimes takes 10 minutes for the program to finish each of the several optimization steps inside the repair wizard.
I have already tried the following to resolve the problem:
- Tested it on an older Core 2 Duo E8600 with 4GB of RAM under Windows XP 32-bit -> very SLOW
- Tested it on a fast new Xeon E31280 with 16GB of RAM under Windows 7 64-bit -> very SLOW
- I installed the latest patch for Moldflow -> very SLOW
- Took the model into Moldflow 2010 and used the wizard in the same way -> very FAST
Therefore the only solution for me is to use Moldflow 2010 instead of 2012. Does anybody have the same problem? Is there a solution?
Thanks in advance
Roger
Hello
I have tested the mesh repair wizard on a few 3D models I have and I am not seeing the same problem. I would suggest you raise a support request via the subscription centre and then we can take a look at your model to see could be causing your issue,
What was the CAD format of the initial model you read in?
Hello Paul
All the CAD models I get are in Parasolid format. Do you think this could cause the problem?
I will try and find a non confidential model that I can upload to the subscription center.
Best Regards,
Roger
Hello Roger
The Parasolid file should not make a difference. I will look out for your case in Subcription centre.
Paul
