Moldflow Insight Forum
Welcome to Autodesk’s Moldflow Insight Forums. Share your knowledge, ask questions, and explore popular Moldflow Insight topics.
Mesh Import Formats
5 REPLIES 5
aty02
1290 Views, 5 Replies
Mesh Import Formats
I am having a problem with aspect ratio... I am getting many high aspect ratios even after repairing them with the mesh repair wizard. Moreover, there are too many of them so I can't fix them manually.
So I am trying to mesh my part with another software and then import it to moldflow.
Is there a COMMON format for importing a mesh from another software ?
I tried ANSYS and Netgen, but there is no common mesh format between them and moldflow !!
Any solution ????
5 REPLIES 5
mtrujil1
in reply to: aty02
Hi aty02 !!
You can try with other software to mesh part and the export the mesh with a compatible extension with moldflow,
for example im using ANSA and after review the quality mesh (Aspec Ratio, Interference, Overlaps, etc) i export the mesh as  .nas (NASTRAN)!
please see below the ext availables to be imported in MF
mtrujil1
in reply to: aty02
Please see the image
maxmarautodesk
in reply to: aty02
Hi aty02,
I cannot give you an extensive answer. But from one of my posts I know that harald.goetz here in the community also uses Netgen for meshing and he seems to me to be a quite advanced user. According to his post, he used the .bdf and .nas file format for the transfer of a surface mesh into Moldflow.
You can find the post I am refering to here:
http://forums.autodesk.com/t5/simulation-moldflow-insight/problems-with-quot-precise-match-quot-whil...
Hope this helps, regards,
Max
mppkumar
in reply to: aty02
Hi
You can mesh in 3rd party software and export the file as .nas and can be imported into moldflow without any trouble
M P P Kumar
M P Pradeep Kumar
If my views / comments acceptable, provide "Kudos" as appreciation, if answers your query, please click the "Accept as Solution"
sabarinathan1021
in reply to: aty02
You can use Hypermesh to mesh your part, you have to create your mesh using NASTRAN Profile in Hypermesh.
You have to select Minimal Normalized after meshing / before correcting mesh.
This setup will give you the aspect ratio values would be closer to our Moldflow mesh. Always export as *.nas format while exporting from Hypermesh.
Please find the attached ppt for your reference how to do these changes in HM. Thank you
Regards
Sabarinathan. S
L&T Technology Services
Chennai.
Regards
Sabarinathan. S
Core Engineering Specialist - Plastic, Auburn HIlls, USA
eMail : sabi1021@gmail.com
If U accept the solution... Give us a Kudos.... Happy Learning....Thank you! .....
