I have a new project; it’s a part for water meter, and I need to test this project in materials:
RTP EMI 861
RTP 802 SI 2
DELRIN 100KM NC000
KOCETAL K300
RTP 3481-1 (LCP)
Is it possible to send me the files with these materials? (.udb)
thank you
what you also could do is:
1) Contact the material supplier and ask for an udb-file for simulation of the material
2) If you have measured data, raw data, of material you can contact
datafittingmoldflow@autodesk.com
and get measured data fitted and an udb-file for simulation in return.
(material supplier might have measured data of this material?)
3) Do a material testing at Autodesk Moldflow Plastics Labs.
Autodesk Moldflow Plastics Labs information at:
http://usa.autodesk.com/adsk/servlet/item?id=13151393&siteID=123112&linkID=13030537
4) Search for an equivalent existing material grade in material database
Hope this helps.
Berndt
