Dear all,
Is it possible to search only PA6. If i give PA6, it is also displaying PA66 and other blends, Also If i want to search only PA66 (unfilled), is it possible? we may have to use any type of strings like *.PA66 or something like this? Attached is a picture for reference. Thank you very much in advance to whom will be so kind to answer!
Regards
JK
Solved by nordhb. Go to Solution.
tick "Exact string match" below Substring.
PA6 without "Exact string match" returns 1148 matches in AMI2012,SP2.
PA66 with "Exact string match" returns 552 matches in AMI2012,SP2.
Sort results by clicking headline "Filler data: Description"
The unfilled will be grouped, and other filler data as well in alphabetic order.
P66 from above shows 185 unfilled.
Hope this helps.
Berndt
