Discussion Groups
Simulation Moldflow Insight
Valued Contributor
prabu27
material import
409 Views, 1 Replies
08-29-2013 04:37 AM
Dear all,
              some of the material not available in our moldfloe material database.
i want to import new material into database.
i want to know is it possible?
if possible means how to import?
and which format required to import?
pls help me anyone....
Please use plain text.
Product Support
nordhb
Re: material import
08-29-2013 05:09 AM in reply to: prabu27
the format used for material database is called udb, a Moldflow specific file.
It is possible to have a personal databases.
In Help look in:
Materials and databases
Materials and databases > Material databases
Materials and databases > Material databases > Personal databases
What you can do:
- Contact the material supplier and ask for an udb-file for the material
- If you have measured data, raw data, of material you can contact
datafittingmoldflow@autodesk.com
and get measured data fitted and an udb-file for analysis in return.
(material supplier might have measured raw data of the material?)
Autodesk Moldflow Plastics Labs information at:
http://usa.autodesk.com/adsk/servlet/item?id=13151393&siteID=123112&linkID=13030537
Hope this helps.
Berndt
Berndt Nordh
