Moldflow Insight Forum
Welcome to Autodesk’s Moldflow Insight Forums. Share your knowledge, ask questions, and explore popular Moldflow Insight topics.
map heating results of part insert to moldflow?
3 REPLIES 3
452 Views, 3 Replies
I did a heating simulation in CFD for a part insert.
Now I would like to map these results as starting temperature for a moldflow analysis.
Is this possible?
Philipp
3 REPLIES 3
madhukeshwart
At present it is not available... But
If you have pre-heat temperature.. you can assign one value of temperature to insert. But cant map different temperature for each element
Madhukeshwar Talwar
FORD MOTORS PRIVATE LIMITED, Chennai
mail: madhukeshwart@gmail.com
09600060862
Please use . Accept as Solution and Give Kudos as appropriate to further enhance these forums. Thank you! .....
phammer
in reply to: madhukeshwart
HI everybody,
answer I got from support was interesting.
Only workaround they had was to split the insert in several bodies and assing different starting temperature.
Greeting Philipp
madhukeshwart
in reply to: phammer
it is like for each element ...assign a value..!!
Madhukeshwar Talwar
09600060862
