I recently upgraded to Moldflow 2012 and i noticed that "locking views" across multiple views/studies only locks the orientation and not the zoom.
What i mean is, when i "lock all views" from one window and then click on the other window, the orientation stays the same but the zoom level snaps back to the where the 2nd windows was prior to locking. From this point is remembers the zoom level of each window seperately and keeps snapping to a particular windows last zoom level.
This is very difficult to work with when trying to create a clean report across multiple views/studies.
Nish
Solved by jim.mcguire. Go to Solution.
Greetings,
I have noticed this problem also, and reported it to support back in early July. Moldflow confirms that this is a bug (feature?) and will work on correcting it.
Thanks for sharing that bit if info. Looking forward to a fix soon.
Nish
