G'day Sir,
I've been noticing that no one has tried to answer your question, I suspect primarily because we are unsure of what you are after. If the lambda you are after refers to the eigenvalue solution, that only applies to a linear buckling analysis in the warpage solution. If you are running a buckling analysis nd the eigenvalue solution is less than 1.00, that indicates that the predicted shrinkages for your part will produce an instability in the warpage, and that a small deflection analysis will be inadequate to characterize the warpage. You will need to then run a large deflection analysis.
If the eigenvalue (lambda) solution is well above 1.00, then the small deflection analysis should be adequate.
Hope this helps.
Bob Sherman
Senior CAE Analyst, RTP Company
