Moldflow Insight Forum
Welcome to Autodesk’s Moldflow Insight Forums. Share your knowledge, ask questions, and explore popular Moldflow Insight topics.
Importing SIMLAB Mesh into Autodesk
7 REPLIES 7
Message 1 of 8
Vaideeswaran
847 Views, 7 Replies
Dear Moldflow Users,
Is it possible to import the mesh generated in SIMLAB to Autodesk moldflow.?
If so, what is the type of file format to be imported to Autodesk Moldflow?
7 REPLIES 7
Message 2 of 8
It is possible
Try the following formats
1.   *.nas
2.  *.pat
3.  *.bdf
Madhukeshwar Talwar
FORD MOTORS PRIVATE LIMITED, Chennai
mail: madhukeshwart@gmail.com
09600060862
Please use . Accept as Solution and Give Kudos as appropriate to further enhance these forums. Thank you! .....
Message 3 of 8
Thanks for your reply. But, I do not get any of the formats you mentioned.
The available formats in SIMLAB, when i go to file-->Export are
GDA
Parasolid
STL
VRML
Facet Geometry
Exporting in these formats are not usable in Autodesk.
Please advice.
This e-mail message is intended only for the use of the intended recipient(s).
The information contained therein may be confidential or privileged,
and its disclosure or reproduction is strictly prohibited.
If you are not the intended recipient, please return it immediately to its sender
at the above address and destroy it.
Message 4 of 8
*SIMLAB tool is mainly used for power train models.*
*There must be option to export FEM models. I never used this tool.*
*Better take help from Altair - tech support team. *
Madhukeshwar Talwar
09600060862
Message 5 of 8
mayur_dhumal
in reply to: Vaideeswaran
As you are saying STL is available, what is the problem then? You can export as STL & import in Moldflow.
Mayur
Message 6 of 8
Mayur.
Simlab is meshing tool..
Regards
Madhukeshwar
Madhukeshwar Talwar
09600060862
Message 7 of 8
harald_goetz
I have used simlab and it can export a surface or 3D mesh in Nastran format (so: *.bdf or *.nas).
No problem for Moldflow to read that in.
Greets
Harald
Message 8 of 8
In Altair Simlab.
File -> Export -> Other
Here you can select the Nastran .bdf type
