Hi everyone,
i did one small comparison study with simple rectangle geometry 150*60mm with 1.5mm thickness
i have choosen Lexan 121 material .
i found huge pressure difference between both studies
please find the picture.
only gate position is different for both studies, i wnt to know the reason?
It is difficult comment, without seeing the study files and please do share study files
I dont know how to attach the study. This is simple rectangular geometry the dimensions of the part is attched here.
Mesh type used : 3D with 6 layers
Material used Lexan 121 (MF tested)
Please try it by your self .
Thank you,
Prabu.k
Hi
I have tried with the sizes as mentioned by you and noticed similar pressures.
Request to cross-check the process parameters set by you once again.
M P Pradeep Kumar
Hi ,
Here i have attached the study files .....
hi M P Pradeep Kumar!
i tried the same scenarios and my results were same that the results obtained by Prabu. but my part design was with 150mm x 60mm x 1.5mm
Please see the images attached.
i tried with different Scenarios
1 Mesh type 3D, Mesh generated in MF2012 (DD and after 3D), Aspect Ratio <6, Match Perc. 100%, Edge Length: 2, E.L Through Thick: 2.5. Gate: Left Side, Part Dimension 150 x 60mm x 1.5mm
2 Mesh type 3D, Mesh generated in MF2012 (DD and after 3D), Aspect Ratio <6, Match Perc. 100%, Edge Length: 2, E.L Through Thick: 2.5. Gate: Right Side, Part Dimension 150 x 60mm x 1.5mm
3 Mesh type 3D, Mesh generated in Ansa & Mf2012 (ANSA DD and after MF 3D), Aspect Ratio <6, Match Perc. 100%, Edge Length: 2, E.L Through Thick: 2.5. Gate: Left Side, Part Dimension 150 x 60mm x 1.5mm
4 Mesh type 3D, Mesh generated in Ansa & Mf2012 (ANSA DD and after MF 3D), Aspect Ratio <6, Match Perc. 100%, Edge Length: 2, E.L Through Thick: 2.5. Gate: Right Side, Part Dimension 150 x 60mm x 1.5mm.
5 Mesh type 3D, Mesh generated in Ansa & Mf2014 (ANSA DD and after MF 3D), Aspect Ratio <6, Match Perc. 100%, Edge Length: 2, E.L Through Thick: 2.5. Gate: Left Side, Part Dimension 150 x 60mm x 1.5mm
6 Mesh type 3D, Mesh generated in Ansa & Mf2014 (ANSA DD and after MF 3D), Aspect Ratio <6, Match Perc. 100%, Edge Length: 2, E.L ThroughThick: 2.5. Gate: Right Side, Part Dimension 150 x 60mm x 1.5mm
Hi mtrujil1
M P Pradeep Kumar
Hi All,
I can confirm I have similar findings to what were reported by Mppkumar.
Here the computation conditions are based on 3D solver, MF2014, same Lexan 121 mf tested material with 150x60x1.5 mm geometry.
I have checked the files that was attached in the beginning of the thread and noticed something mush have been dodgy with the meshing (check the fill pattern the flow front looked very unusal).
My results are as follows.
The VP pressure using an STL geometry, mesh is 6mm, unstructured
gate in +X dir.: 90.9 MPa,
gate in -X dir. 89.3 MPa. - identical values
The VP pressure using an IGES geometry, mesh is 6mm kept only as a reference value but controlled by divisions, structured.
gate in +X dir.: 93.3 MPa
gate in -X dir.: 87.3 MPa - almost identical.
Regarding accuracy the best is to perform a mesh sensitivity analysis to contrast accuracy and computational time.
An unstructured mesh, provided it`s fine enough does the job perfectly and should provide sufficient accuracy.
Best regards,
Martin
Hi Pradeep Kumar
i already ran your sdy file, and the pressures results were very similar with both scenarios.
your Global Edge Length selected was 3mm.
i tried to simulate with your globalk edge length, but instead to use the 3D mesher Advancing Frront with 4.5 value (Rule from Moldflow fundamentals Training "Use a value between 0.5 and 1.5 times the global Edge length for Edge Length through thickness parameter"), was selected 3D Mesecher Legacy.
And the Results for Bot scenarios were similar too. see the images
Martin, which 3D mesher option was selected for your analises.? Why the difference between these option?
Regards
I would like to reply with a question here:
The advanced front mesher is the default option, right?
So it should bring better results.
Could it be, that with gate refinements your results might be enhanced?
Because what I saw here so far seems odd.
Best regards
Harald
hI hARALD
Yes, the Advanced Front is a Default option, but the results are not according with the logic.
i tried too, i drew the gate with beams elemtns (6 beams) and the results were the same :(.
Could you simulate the exercise? Part dimensions (150mm x 60mm x 15mm)
regards
Hi.
I'm also really interested by this problem.
I made some simulations to try to understand.
Here are the results I got :
Gate position Side Y- Side Y+
initial simulation 27,4 42,6
Gate size imposed : 1 mm 32,3 48,5
mesh 12 layers instead of 6 40,4 45,3
PC : Makrolon 2405 29,6 42,9
Gate not in the edge but near 27,7
Part turned in the plane XY 27,4
Mesh Midplane 45,6 45,6
Mesh Dual Domain 47,3 46,5
So, I also found big differences of pressure with the 3D meshing.
Regarding the results got with the Midplane and DD , it seems the problem comes from an underestimation
when the gate is in the Y- position.
I hope someone will give a good answer to your question.
Signature: "Maybe Moldflow does not work properly, but the real world neither" my son...6 years old 😉
1. If Study with feed system ...... I doubt there will not be any differences.
2. If study without feed system ....It can happen due automatic gate concidered and thickness at gate region.
3. It should not be difference in both the case.
4. Gate contact diamter may be a culprit for 3D model witout feed system
