The anchoring does NOT change the actual deformation of the product, just the way it is displayed!
Without specifying an anchor plane (e.g. the default display) the warpage result is displayed in a way that it best 'fits' the orriginal model (the method is called 'best fit'). This method gives a very good over all idea of where the part is shrinking and warping more or and where less. You will often find that somewhere in the middle of the product, you have a blue area with 0 displacement.
The anchors allow you to study the warpage result in more detail (e.g. how much the product shrinks and warps with respect to a specific reference). The first anchor point defines that the initial cavity and the warped part have 0 displacement. Remember that just by specifying this one anchor point, all the colors will change, because you moved the area where you have 0 displacement ; BUT the actual shape of the warped product does not change, it's just that the reference points have moved.
So, with the first anchor point, we define the 0-deflection (origin), and with thesecond and third anchor points we specify the x and xy plane These three points effectively become your local coordinate system. You can use the results query to get detailed information on how much a point deflects in 'local' X Y and Z direction.
There is some really good help on the concept of anchoring.
I hope this helps
Hanno van Raalte,
Product Manager - Injection Molding & Moldflow products
