Moldflow Insight Forum
Welcome to Autodesk’s Moldflow Insight Forums. Share your knowledge, ask questions, and explore popular Moldflow Insight topics.
How to interpret volumetric shrinkage
1 REPLY 1
kulandaivel_palanisamy
2217 Views, 1 Reply
Dear all, I like to know how to use volumetric shrinkage. Is it directly related to mold shrinkage? Attached is a picture of a sample part for your reference.
I like to know how this result is compared with the shrinkage values in the material databse. Please share your views.
Regareds, JK.
1 REPLY 1
in reply to: kulandaivel_palanisamy
Well by definition the Volumetric Shrinkage is the sum of Parallel Shrinkage, Perpendicular Shrinkage and Thickness Shrinkage. Usually, the thickness shrinkage dominates here so the linear shrinkage is much less than 1/3 of the volumetric shrinkage. The distribution of the volumetric shrinkage between those three linear shrinkages is dependent upon many factors but usually, yes, the higher the volumetric shrinkage the higher are the linear shrinkages (at least for unfilled materials).
